needing help with my civic b16
smith_sir
Post by smith_sir »
just got a honda civic 1992 SIR import with the b16 engine. has custom manifold, exhaust and the AEM induction. currently pushing 176.3 bhp was wondering what the best thing to do would be in terms of these hondata things. and just to let you know im quite new to this so clear explanations please thanks :)
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
josevives2008
Post by josevives2008 »
hi.
Why not the s200? If you already latienes.
What I have to connect to my ecu for my B16?
thanks.
The s200 has been discontinued. If you want to be able to tune yourself, just get the s300.
josevives2008
hi.
And if you already have. What are you doing?
I have, but not connecting.
How do I connect to the ecu?
What do I need?
an emulator and a program.
How do I connect?
thanks.
