S300 & HFS-5 Aquamist - Naturally Aspirated High Compres
Posted: Wed Mar 18, 2009 12:05 pm
I have an idea of how to install it!
I have problems with the knocking, I want to install and use the fail-safe function in the ecu
I want to change the timing when you have problems with the Water / methanol system. Here is an idea:
Nitrous/Aux Parameters:
Fuel & Ignition - specifies changes to fuel and ignition when nitrous is activated.
The maximum retard is 40 degrees, and the ignition timing can be retard to a maximum of 10 degrees BTDC.
Diagram Hondata:
5. Fail-safe window output (SW GND)
When flow signal falls inside the fail-safe window,
pin7 will switch to ground immediately. This output
can be used to activate a solenoid valve to increase
boost pressure. This output can also be used to
switch MAP (GND active) on an ECU.
you have any other idea to use the fail-safe for Aquamist?
Diagram Hondata:
