Unable to upload/download, clear ecu
Posted: Sat Mar 14, 2009 10:56 am
by K20 performance
Hey guys,
I have the following:
Kpro serial: 03384
PRB ecu
Car: EU CTR-SC EP3 K20A2
Vista with v 1.3.5.3
The following is happening,
When i connect my laptop to the ecu i get online and can get the ecu info etc, so far so good.
I turn on the ignition, ignition comes on in kmanager, try and load my map, it starts for 1 sec and then it stops with ;upload failed;, if i try to clear the ecu i get 'clear security failed'.
If i try to update drivers i get 'error updating usb driver/ acces denied.
Also, if i turn on the ignition without the laptop connected, the CEL stays on and the car starts in limp mode.
If i do this with kpro connected to my laptop, on ignition the CEL comes on and goes of and i can start up the car fine with no problems at all.
Anybody have an idea what might be causing this?
I did have my dash out of the car but everything electrical is installed correct.
Can it be the laptop im using? I am using a different one now then the one the map was uploaded with.
Thanks in advance!
Posted: Mon Mar 16, 2009 9:59 am
Posted: Tue Mar 17, 2009 8:59 am
by K20 performance
At the time i was using version 1-3-5.
I have updated to 1-3-5-1 but not tried to connect to kpro yet.
Also just saw there is another update, ver. 1-3-4-0, will download that one now.
Edit, unable to download 1-3-4-0 at the moment.
Posted: Tue Mar 17, 2009 2:26 pm
Posted: Wed Mar 18, 2009 9:13 am
by K20 performance
Downloaded and installed, gonna hook it up to the car this weekend and see what happens.
Will let you know.
Thanks.
Posted: Mon Mar 23, 2009 9:24 am
by K20 performance
Ok, did some driving again this weekend and still the same problem.
I turn on ignition, ecu does self check cel goes on and back off and after a couple of seconds the cel comes back on and stays on.
If i turn ignition off, plug in the ecu to my laptop, turn ign on and all is fine, i can start the car without a problem and all runs fine.
I can then plug the ecu back out from the laptop and everything stays fine till i turn off the car and try to start back up after a while. If i start up a couple of sec after turning off the engine everything stays good and runs fine.
But if i turn on the ignition, wait for the self check to be done and start it up it starts up fine and a couple of sec later the cel comes on, if i now plug in my laptop the car goes into limp mode immediately, idling very erratic and what not. If i turn the car off with the ecu still connected to the laptop and start back up all is fine and well.
Thinking of sending the ecu up for a complete check up so i have an idea where to look for the problem.
Also still unable to do the things described in the first post.
Any ideas?
Edit:
I should also mention that a motorbike in my garage cought fire and caused a lot of soot damage as my windows were open, the flames stayed by the motorbike and nothing else cought fire.
Whole interior and wiring is new.
Posted: Mon Mar 23, 2009 11:40 am
I would suggest contacting Guy at CPL Racing in the UK and arrange to send it to him for testing.
Posted: Thu Apr 23, 2009 1:44 pm
by K20 performance
Update:
Send the ecu to CPL Racing to check out, the kpro board was broken but the ecu was still good. Had the kpro board replaced with a new one and all problems gone.
Thanks for the input and thanks CPL Racing.
Posted: Tue Aug 04, 2009 10:16 am
by EM204T
Have the same problem! New kpro for my EM2 does the same thing but
it new and guy from CPL uploaded a map just fine. How can my kpro board
be broken?
Posted: Tue Aug 04, 2009 10:54 am
You will have to contact Guy for assitance with this.
Posted: Fri Aug 21, 2009 1:07 am
by EM204T
Ok ecu went back to CPL and guy tested it. Kpro stil ok but the ECU is FRIED.
Wen i checked wiring with guy and guy says he checked with hondata
and they confirm that i didnt need to repin! Now that the ECU is FRIED, no waranty result have to buy a new ECU WTF!
Posted: Sun Aug 23, 2009 11:14 pm
by sujinX
im having the same problem as the OP. i dont know what to do :-(
Posted: Mon Aug 24, 2009 9:48 am
by EM204T
well you can send it in and let them check the kpro and ECU if you have tried everything else from updating soft,usb,..... that will also be the info you will
get here! hope you have better luck then me with it!
