Temp sensor & AC is not working????
pwpdc5
Post by pwpdc5 »
Hey i plugged in the kpro for my 05-06 rsx-s and my temp sensor in the car does not work. Also the AC condenser does not turn on to blow out cold air.. i double checked and plugged back in my old ecu and everything works fine. please help me out, thanks
You have the multiplexer disabled. You must set it to normal operation and upload the calibration.
pwpdc5
Post by pwpdc5 »
Thanks.. I got my temp sensor to work but now kmanager says readiness code ac refrigerent not supported...
Ignore the readiness codes, they mean nothing.
pwpdc5
Post by pwpdc5 »
Yea but what causes my a/c compressor not to kick on?? It's not the compressor since I have plugged in the stock ecu like 5 times already just to have some a/c... All the wires on the harness seem to be perfect.
I didn't spend $1500 to have no a/c...
Please follow the posting guidelines and provide the calibration you are using and a datalog.
pwpdc5
Post by pwpdc5 »
The calibration is the first one u have on kmanager for the k20z1 and what type of datalog u need? Doesn't it matter if I give you one on idle?
There is a bug the AC in V1.3.5. Update to 1.3.5.1 and upload again.
