High Speed Table Tunning
cesarjr230675
Post by cesarjr230675 »
With the S300/ECU plug to the car and the car running, I can not make the correct tunning at the high speed tables, Which are the best practice to make it possible this tunning?
Regards,
César
Cesar Jr.
In the 'Options' menu uncheck 'Tables follow VTEC'.
cesarjr230675
S300 High Speed Table
Thanks, but Still not understand a little.
If we uncheck this option, I can get my car running and follow it behavior at more than 4000rpm?
With the datalogging "on", it is possible?
Regards,
Cesar
Cesar Jr.
Vulak
Post by Vulak »
Hondata's answer got me lost here :D
I though the situation here is that ceasar wants to tune high speed ign/fuel maps which are maps that car uses when vtec is enabled, correct?
if he disables vtec, he wouldnt be using high speed maps at all?
and to tune the vtec tables, best practise would be setting vtec point to around 3000 RPM and lower the values for vtec minium throttle and speed?
I believe the original question was how to change the high speed cam tables when datalogging. If 'Tables follow VTEC' is checked, then the low speed table will always be shown when idling, so changes cannot be made to the high speed tables. 'Tables follow VTEC' does not change the operation of VTEC.
Puedo obtener un orador español para ayudarle?
cesarjr230675
Thank you friends,
Yes the problem is that when we are in the road tunning the car, the slow speed table is always shown. It do not change automatically to high speed table, that's why I am worry to be making changes at low speed table and would not work at high speed.
I am worry because, I want to make the more perfect possible combination for the MAP (fuel-air ratio) for my car (turbo kit bolt on). As you know with little fuel, I can blow out the engine at high rpms, that why i am worry.
Thanks for your help, every little comment you guys told me.. are very usefull
Cesar
Cesar Jr.
