wideband in place of o2 sensor
Posted: Sat Mar 07, 2009 7:53 pm
by KING
I have a 94 civic dx, built gsr sc61 and s300. Im wondering if there is any reason not to use my wideband in place of the factory o2 as in NO factory o2 I just wire the wideband in to send signal to ecu.
Posted: Sat Mar 07, 2009 9:20 pm
by jdmspecdc5
thats exactly what i did. just make sure you wideband has a narrowband output for the ecu so it will run correctly in closed loop.
Posted: Sat Mar 07, 2009 9:41 pm
by KING
jdmspecdc5 wrote:thats exactly what i did. just make sure you wideband has a narrowband output for the ecu so it will run correctly in closed loop.
I have the lc-1 wide band and it has the output. have u had any problems running it this way?
Posted: Sun Mar 15, 2009 11:11 pm
by hybridcivicls-t
I have the AFX NGK wideband. I was going to do that but the wideband placement is a little further than i want. so i opt to keep the stock one in and use the wideband
you wont have any problems with it though
Posted: Mon Mar 16, 2009 3:56 pm
by 98h22
will the car run correctly in closed loop without a o2 sensor or wideband hooked up to s300?
Posted: Mon Mar 16, 2009 5:03 pm
No you cannot run in closed loop without a narrowband signal or a simulated narrowband signal.
Posted: Mon Mar 16, 2009 7:38 pm
by 98h22
is it safe to always be in open loop until i get my new o2 sensor?
Posted: Tue Mar 17, 2009 10:11 am
That all depends on the tuning.
