12psi stock map sensor?
Posted: Fri Feb 27, 2009 11:08 pm
by JPsi02
So what actually happens if i try to run 12psi on my stock A3 map sensor? Will it just top out at 10 or so? and i will be stuck with the single columb of tuning ability sense its not reading the real boost? I mean i have a boost gauge anyways.
I also have a 94 civic with a turbo Z6 on S300 that is also on the stock 10psi map sensor but can run like 15psi without breaking a sweat its just hard to tune sense it sticks at reading 10psi lol. I just want to know if my ep3 will act the same way or if it goes haywire and fuel cuts (i would raise boost cut) or what exacly goes on?
I plan on getting the hondata 4bar map when i get paid but i want to race someone in the next couple days and id rather be at 12psi then 10 lol.
Posted: Sat Feb 28, 2009 8:59 am
by cranny
is your engine really worth it?
Posted: Sun Mar 01, 2009 1:16 pm
by locash
The map sensor will just stop reading past 10 or so.. Technically, you could just set your 10psi load columns for the desired fuel/spark delivery for 12 psi, but then again, doesn't it make more sense to do it right?
