which calibration/tune should i use temporarily?
nicotine
Post by nicotine »
so we're ripping out my k20a3 out from my ep3.
dropping in a k20z1 using a 04 type s tranny (to avoid using vss signal converters).
so it'll be k20z1 (pretty much the same as A2, but supposidly SLIGHTLY bigger cams, but not by much), RBC intake manifold, header, 2.5" exhaust, high flow cat, air intake.
what tune should i use for kpro to get me rolling so i can take it from the shop to the dyno?
i'm not gonna beat on it, or vtak all over the place. just need a decent map to get me rolling so i can take it to be tuned.... :D
Use the k20a2-rsx-2005.kal, un-check 'Use counter shaft driven speed sensor'
