Lambda overlay
dmramos
Lambda overlay
Post by dmramos »
does this function work when wiring a wideband signal into the eld input using the s2000 kpro? thanks!
Yes
dmramos
Post by dmramos »
Spunkster wrote:Yes
for some reason i cant get it to work....no numbers appear in the delta lambda tab in the kmanager program
cranny
Post by cranny »
are you reading it in the display?
dmramos
Post by dmramos »
no, i am using it under the table tab, click on fuel tables, then select the delta lambda and am not getting any numbers, just a blank table.
cranny
Post by cranny »
your not understanding what im saying. are you getting a reading at all from the wideband in display under A/F?
dmramos
Post by dmramos »
sorry, yes i am
dmramos
Post by dmramos »
would you mind checking my ignition values....this is for a 2004 turbo s2000
cranny
Post by cranny »
how many PSI you running?
dmramos
Post by dmramos »
10 psi
cranny
Post by cranny »
looks ok. do you ever hear spark knock? if you do back it off. too much timing in a boosted engine will kill it quick. specially if its a stock engine. a dyno is really the only way to tune ignition properly.
