Advice needed for grounding points
retroid
Post by retroid »
Hello eveybody! Many thanks to Hondata for having such a great costumer suport as this forum! Full RESPECT! :D
I soon will go for K Pro, but first I want to "prepare" the car for it. I want to instal some gauges (oil temp/pressure) and a wideband (I think the zeitronix one)....
I also want to make a grounding kit. We al know the benefits of this kits and I want to add 3 more grounding points:
first I want to conect this, directly to the negative battery instead of valve cover
the other 2 will be:
the ECU case
and this :
(the black wire in the picture is from a vtec light)
It's safe? What do you think? Many thanks! :D
The ECU case does not need to be grounded.
The factory grounds are all you need. Make sure you have the timing cover side ground and the transmission grounded to the chassis.
I would recommend cleaning the stock ground points and doing nothing else. There are three critical grounds:
- transmission to chassis
- wiring harness to cylinder head
- chassis to timing cover (via engine mount)
Don't ground the ECU case.
retroid
Post by retroid »
Thank you! :)
Garrett_si
Post by Garrett_si »
why using a zeitronix wideband?
the OEM wideband does a great job
fonz600
Post by fonz600 »
Cause he has a EUDM EP3 which comes with a narrowband.
