Hi guys,
My car has developed a wierd problem, there seems to be an intermittent missfire under higher boost that isnt apparant at lower boost, though nothing has changed withthe car and i havent had any problems previously. If the car starts to play up during acceleration and i change up a gear and put my foot flat down the rev limiter is active.
I have been able to datalog this problem, i can find anything that identifies the missfire from the datalog, but am assuming that the 2 problems are interlinked.
Datalog 'ok 7psi' shows the car acting normally at 7psi.
Datalog 'rev limit on gear change' shows the rev limit activated for no apparant reason.
The 2 datalogs labelled missfire are from when i was accelerating and the car was 'missfiring' but i cant see anything wrong with the log, maybe the injectors are cutting but the refresh rate of the datalog doesnt show this?
Any help appriciated.
Craig
Wierd Missfire and Random Rev limiter probelm
jordancivic
jordancivic
jordancivic
