Lean under load
Posted: Sun Feb 08, 2009 1:44 pm
- serial number of your K-Pro: 370820-prb-a08
2068-800092
- the calibration (as an attachment): is a tune from a buddys car that runs perfect
- what sort of vehicle you have: 93 civic
- what sort of ECU you are using: PRB
I have a turbo k20z1 eg. I am having alot of trouble getting the car get to target a/f above columns 8, however i can tune for 14.7 for part throttle with no problems.
No matter how much fuel i add it wont richen up in columns 8 on into boost columns. I also added a inline pump and set base pressure at 70psi. Still wont get down to 11.8 in the boost columns. I got to the point where i went to an extreme and just added 100% fuel and still just spikes 14+ a/f under load, sometime even 17's.I have an intank pump feeding an inline and 1000cc injectors. Base pressure is around 70 psi. Getting the fuel isnt the problem.
I also tried cleared security, tried a friends k-pro, put new plugs, new wide band, took apart my FPR, injectors, and fuel filter and still the problem consists.
Map sensor is AEM 3.5 bar
Could it be my PC or k manager being currupt b/c it just doesnt want to do anything when it goes into boost.
I have my kal. attached.
2068-800092
