analog inputs with OBD2a/2b Hondata ecus...WHICH PINS?
OTT
Post by OTT »
I use hondata ecus with OBD2a and OBD2b built in connectors.
I wish to use the OBD1 pin references D12 & B6 on these ECUs, but I need to know which pins to feed them into?
thanks
I do not believe that these OBDI pins are connected to the OBDII connector.
OTT
Post by OTT »
spunkster, thanks for the link, it would appear that b6 was not listed at the time.
Hondata the how can i check for certain?
these two inputs are critical for me, I AlWAYS use them for various customers with OBD1 / adaptor harness.
B6 is not built in. You will have to run a wire to that location...this may involve soldering dierectly to the board if you have a build in adapter harness.
OTT
Post by OTT »
D12 definitely built in?
Please look at the link I posted above
OTT
Post by OTT »
I did look at the link posted above but since ou were telling me one ma not be connected on the ecus with built-in adaptor, I wanted to know from the source if the other was.
I will get one from stock and check it over.
