s300 and aem 5 map sensor questions...
topendusa
Post by topendusa »
are the default settings on the s300 for a 5 bar the same settings for a aem 5 map sensor?
bc my map sensor is reading lower than my autometer manual gauge, and when it gets to low the computer throws a cel for the map sensor
if the sensor calibration is off how do i adjust it and not mess up my tune?
Martian
Post by Martian »
no
thank you, thank you, I'm here all week
In Smanager, go to Help, Contents and search for "scalar".
D@nny
Post by D@nny »
im having the same problem since I updated my software. down shift or go into heavy vacuum and the car throws a code for the map sensor and wont rev. cycle the key and it drives fine. also on an aem 5 bar what do we have to do to fix it?
D@nny
Post by D@nny »
scalar for aem 5 bar 1290 off set -645
I cant believe you ask them for the offset and scalar for a popular sensor and they tell you figure it out...typical hondata support.
If you have a problem, please follow the posting guidelines and provide a datalog and calibration. Unwarranted abuse will not further your cause.
