TPS question for the enthusiast!
mnjdmek4
Post by mnjdmek4 »
does anyone know if we can calibrate a non honda tps to work? for instance, different resistance or voltage range for a tps that may not read the same for an stock one?
Martian
Post by Martian »
It calibrates by pressing a macro throttle closed, and a seperate macro for throttle 100% open, and records the voltage each time. I see no reason why it wouldn't work fine, aside from a resistance problem.
thank you, thank you, I'm here all week
More than likely it will not work properly. The adjustment function in the software is for use with a Honda sensor that is very slightly misalligned.
Martian
Post by Martian »
Spunkster, is there a limit to the voltage offset?
mnjdmek4
Post by mnjdmek4 »
Martian wrote:Spunkster, is there a limit to the voltage offset?
i too would like to know.
