Switch for secondary map...?
88ED8
Post by 88ED8 »
When wiring in a switch for secondary maps, do I cut the wire or tap the wire at the D2 position...?
Check out my Turbo H2B CRX http://honda-tech.com/zerothread/2086488
You need to cut the wire, or every time you hit hte brakes, you will go on to the secondary maps.
88ED8
Post by 88ED8 »
Spunkster wrote:You need to cut the wire
That's what I thought, just wanted to make sure... once the wire is cut my brakes will no longer show up in my datalogs, right?
correct
88ED8
Post by 88ED8 »
Alright, thanks...
laziebun
Post by laziebun »
So do it like this? But this is using the A/C switch wire in B5 slot.
yes
