B16a injector problem
crx_54727
Post by crx_54727 »
i have a problem with my injectors. the injectors are not the origianal they are from a 1990 acura integra b18 non-vtec. there are two wires on the injectors and they both have power when the key is off. the when the key is turned on they all still have power. now when you turn the key to start it there no power and no fuel coming out of the injectors. now when we ran direct ground from the battery gas comes out. if you can give me any help or suggestions i would appreciate it. thanx
crxvtec
DaX
Post by DaX »
Check all your engine ground connections. Make sure the metal is making good contact [you may need to sand contact surfaces down] and all connections are tight.
