4 Bar MAP Sensor and wrong table scalers?!
Posted: Tue Jan 20, 2009 4:08 am
by Roman_CTR
I want to run a 4 Bar MAP Sensor with KPro.
I changed it in the parameters. In the options i checked "show 5 Bar Tables".
But in the Tables itself the table scalers are just showing up to 1.9 Bar.
When i click right on the last column, choose change Load index the small edit box shows its right value 2.92 Bar.
Is this a bug or can i change any parameter to display it right?
Thank you!
Posted: Tue Jan 20, 2009 10:30 am
There are 16 load columns. Most calibrations have these mapped to 3 bar. If you are running more boost that that, then you will need to set the load index yourself.
Posted: Tue Jan 20, 2009 10:49 am
What 4bar are you using?
Posted: Tue Jan 20, 2009 1:09 pm
by Roman_CTR
Thank you for the quick answer.
I use the Hondata 4 Bar MAP.
I took a screen shot - please see the attachment.
The strage is, on the screen it's displays 1.9 Bar, but the Edit Load Index shows 2.92. Even when i confirm the editor box the table heading keeps unchanged.
Now, please tell me, in this example: Is the column 16 for 1.9 Bar or for 2.92 Bar?
Posted: Tue Jan 20, 2009 1:38 pm
You must go to Options and select show 5bar tables.
Posted: Tue Jan 20, 2009 4:16 pm
by Roman_CTR
The screenshoot was taken with the "show 5bar tables" option allready selected!
Posted: Tue Jan 20, 2009 4:20 pm
by Roman_CTR
I just tried it again. No luck again.
BTW. nothing changes when i try the options "show 3 Bar Tables" or "show 5 Bar Tables".
And nothing changes when i try different Map Sensors from the Quick select.
Is there any additional step when i select a different MAP Sensor?
Posted: Tue Jan 20, 2009 4:22 pm
No, you have it set to show 3bar tables. There are 24 columns when you have it set to show 5bar tables.
Posted: Tue Jan 20, 2009 4:26 pm
by Roman_CTR
Spunkster wrote:No, you have it set to show 3bar tables. There are 24 columns when you have it set to show 5bar tables.
Really?
Posted: Tue Jan 20, 2009 4:58 pm
I'm sorry, thought this was Smanager not Kmanager.
I've just checked and as long as you have it set to show 5 bar you can go and edit the load index and i was able to set to 4 bar in column 16.
Make sure you go to Options, settings, Units and make sure you have your pressure unit base set to absolute.
Posted: Tue Jan 20, 2009 5:03 pm
by Roman_CTR
Ahhh, hurray it works now.
The problem was the "pressure unit base" was not set to absolute.
Thank you!
