Hondata boost control solenoid using GM 3bar map sensor?
hiperformance
Post by hiperformance »
I know hondata does not recommend using the GM 3bar map sensor, but this car is already tuned with it. My question is, will the Hondata boost control solenoid and system work well with the GM 3bar map sensor? or will I run into accuracy problems? are there any issues I should know about.
Thank you.
It will work as long as you have the correct 3 bar, and you set it all up correctly.
hiperformance
what do you mean correct 3bar? are there different 3bar GM sensors?
Yes, which is why we do not recommend using the GM sensors.
hiperformance
Phew.....what ever one we had worked fine.
