S300 Help
inte
S300 Help
Post by inte »
I keep getting a red blinking light on the usb attachment of the hondata. I know it is supposed to be green. When I am connected it won't let me do anything and it tries to update the firmware data. Has anyone seen this...
From Help, About, what version of software are you using?
inte
Post by inte »
1.4.0.0
What happens when it tries to update the firmware?
inte
Post by inte »
Nothing, if I try datalogin or try to update to the ECU it tries to update the firmware data. It keeps going and going. It doesn't seem to work. It won't let me do anything.
It will not update firmware while datalogging. Close Smanager, reopen it, load a base calibration from File, New, and then upload the calibration. If it tries to update the firmware, let it and do not cancel or interrupt power.
inte
Post by inte »
I will try that. But I know that if I try to load anything to the ECu it will try to update the firmware. After is done updating, if I try to load to the ECU it will try to update again. Any idea why I have a red blinking light on the USB port. I know that when I turn the ignition it is suppossed to be green.
inte
Post by inte »
ok, opened new calibration, but the same problem keeps happening. it is trying to update the s300 firmware. After it updates it continues to do it over and over it doesn't stop. I keep having a red blinking light on the USB.
inte
Post by inte »
This s300 is bad, how can I get it repaired.
Please call us to obtain an RMA number and get instructions and details.
310-782-8278
