Boost cut question.
devilz
Boost cut question.
Post by devilz »
Just wondering what exactly the boost cut does, does cut spark, or turn off the fuel pump or injectors?
Wouldnt it be a little worrying if you were boosting 20psi with the boost cut set at 21psi or more, and then all of a sudden your fuel got turned off??
Wouldnt it be safer to cut back spark instead of fuel?
H22A Turbo Prelude
AndyE
Post by AndyE »
This has been covered several times already, but it's been a while, so:
1) The boost cut is a fuel cut
2) Yes, a spark cut would be safer
3) No, you won't see Hondata implement a spark cut instead of a fuel cut
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
