new DBW s2000 kpro ?
Posted: Sun Nov 30, 2008 8:43 am
since hondata says "Should the K-Pro need repair or maintenance, the stock ECU can still operate the car by itself if the adapter harness is removed and you have stock injectors. The rev limit is lower (7000 rpm) and VTEC disabled". i can drive to my tuner with the stock ecu in after i get the reflash and kpro back from hondata? then install the harness, kpro, and rsx o2 sensor?
also, does the rsx o2 sensor directly plug into the stock s2000 o2 sensor connector?
