new DBW s2000 kpro ?
tjjolliff
Post by tjjolliff »
since hondata says "Should the K-Pro need repair or maintenance, the stock ECU can still operate the car by itself if the adapter harness is removed and you have stock injectors. The rev limit is lower (7000 rpm) and VTEC disabled". i can drive to my tuner with the stock ecu in after i get the reflash and kpro back from hondata? then install the harness, kpro, and rsx o2 sensor?
also, does the rsx o2 sensor directly plug into the stock s2000 o2 sensor connector?
Hondata1
Re: new DBW s2000 kpro ?
Post by Hondata1 »
As long as you have stock injectors, you can drive to your tuner with the stock ECU after reflash. There will also be a basemap for the 06+ S2000 for the K-Pro.
The RSX sensor plugs straight in.
tjjolliff
Post by tjjolliff »
so the kpro comes with a stock masemap so i can actually drive it to the tuner on kpro or would you suggest waiting to plug kpro in once i get to the tuners?
Hondata1
Post by Hondata1 »
The K-Manager software comes with a stock base map you can install and drive to the tuner with.
