ign at idle
Mr Aryan
ign at idle
Post by Mr Aryan »
can someone look into my map and tell me what's wrong and fix it please?
as you can see idle is reading between 6 and 12 ign, while table is saying 16.5 at zero cam degree...
when holding 3% throttle, it looks fine...so my problem is only at idle..
thanks
it's PRB on euro CTR
This is normal. Look in the help file under 'TPS Ignition Problem'.
Mr Aryan
Post by Mr Aryan »
so if i raised the ign at idle to 20-22 degree, would that let the ign stays between 14 and 18 degree?!
Ignition controlled idle is normal. You don't need to fix anything.
Mr Aryan
Post by Mr Aryan »
ok thanks
