Injector driver durability
D-Rob
Post by D-Rob »
Does an injector driver in the K-Series ECU's work 100% to it's capacity until it's smokey death?
Or is the death gradual?
As in, would the injector driver stop working at "X"-amount of duty when used with low impedance injectors (without resistor box), or would it work up until the whole driver burned up?
- Derek
If low impedance injectors are used then the drivers could be damaged so that they fail at a certain current or temperature. Duty cycle only makes a different by influencing the above two conditions.
