ELD imput voltage max?
shiggy
Post by shiggy »
Hi
I just wanted to know if ELD pin accepts imput voltage of 12V.
I was thinking about connecting wideband output to ELD pin though
the wideband outputs 0-12V instead of 0-5V.
I'm worrying about ECU fries with 12V, so please advise.
Also, thinking about comparing A/F from OEM sensor and wideband output.
So I'm thinking about making settings as "use built in wideband" and
put wideband output to ELD pin and see ELD voltage.
Will this work?
The ELD will only accept 0-5V. 12V will damage it.
