D10 Eld
twinkam
D10 Eld
Post by twinkam »
How do I find what wire d10 is on a p28 ecu?
NGIN BUILDR
Post by NGIN BUILDR »
twinkam
Post by twinkam »
Thank you! :D
MugenFoo
Post by MugenFoo »
May i ask :
What is the consequence of disabling the ELD in Smanager?
I noticed at idle, ELD reads about 2.4V ,
with headlights , it drops to 1.5V.
with A/C , it drops to 0.4V
But output from the ALTC pin just reads about 8.5V (maybe a duty cycled signal?, I don't have a scope ) , and overall Batt voltage stays at 14.1V no matter what.
Car is a JDM ITR (has both ALTC and ELD wiring in its stock harness, and no PCS) , donor ECU is a JDM P30 with S300J add-on.
The ELD signal causes the ECU to idle up slightly - there is no change in the alternator control from the ELD.
