Help wiring primary o2 sensor into Kpro PRA ecu??
froshtyv
Post by froshtyv »
Well at the moment my car is running in open loop on the map that comes with the kamanger.
I am running a K20a2 engine from a euro civic type r.
I am runining no o2 sensors on the car,
I would very much like to install one.
But i have a couple of questions.
I had a look at the k20a ecu pin out on the main hondata website, but im not sure if these will be the same for my ECU??
2nd question,
Will i have to install an o2 heater for my primary 02 sensor to work?
If so can this be gotten off honda and where does it go??
All input would be helpfull,
Im running the engine in an eg so its a swap, which is why its not plug and play with my harrness.
I will not be running a secondry 02 as i have not car in my exhaust,
froshtyv
Post by froshtyv »
Anyone know if the k20a pinout is the same as the k20a2??
It is different. I would recommend contacting a European Hondata dealer for help with this, as we do not have the information on the wiring for a European vehicle.
froshtyv
Post by froshtyv »
Spunkster wrote:It is different. I would recommend contacting a European Hondata dealer for help with this, as we do not have the information on the wiring for a European vehicle.
Thanks for the reply,
Someone else said it was different aswell from the us version.
I shall see if i can get in contact with someone this side of the pond.
