K24-20 comp 12.5:1 ITR cams...basemap need
Posted: Wed Oct 29, 2008 2:05 pm
I only want a base map for breakin for run my car to dyno and also to have a base map for it. I expect keep an eyes on all the sensor data and work on ignition if I see some pinking to get a real SAFE map before dyno.
This is my setup...
K20a2 head
K20a Camshaft
K20a valves springs
K20a Intake manifold
Hondata intake manifold gasket
RDX 410cc injectors
K20a2 TB
SRI Aem
DC sport short header
3 inch custom mandrel exhaust line
3 inch high flow cat
ACT streetlite flywheel
ACT street performance clutch
ARP headstuds
K24a3 Bloc
K24a3 balance and lightened crankshaft
Wiseco 87.5mm 12.5:1 comp ratio
Eagle rod
K20a2 oil pump
K20a2 oil pan and baffle plate
K20a2 oil cooler
Hondata KPro...
Run with 91 octane gas
So do you have a map fit a little with my setup ?
PS... sorry if my english suck I usually speak french
This is my setup...
K20a2 head
K20a Camshaft
K20a valves springs
RDX 410cc injectors
K20a2 TB
SRI Aem
ARP headstuds
K24a3 Bloc
Eagle rod
K20a2 oil pump
K20a2 oil cooler
Hondata KPro...
