jdm dc5 speedo problem with kpro
Posted: Mon Oct 27, 2008 12:50 pm
by honda crazzy
jdm itr with euro ctr tranny. my speedo under reads alot!
is there any way to change the pulses from the speed sensor with kpro. the option to use the countershaft speed signal and change values does not work.
someone please advise
Posted: Mon Oct 27, 2008 1:47 pm
No, it is not possible to change the calibration of the speedo with the ecu.
speedohealer
Posted: Mon Oct 27, 2008 2:53 pm
by honda crazzy
if i use the healtech speedohealer(which alters the pulses from the speed sensor), should i fit it between the speed sensor and the dash, or must the ecu also read this calibrated pulse? will the ecu actually make sense of the "altered" signal ?
is it compulsary for the ecu to read this changed signal, cause i don't use gear compensation anyway
Posted: Tue Oct 28, 2008 9:34 am
The ECU must read 4 pulses per wheel revolution.
Posted: Thu Oct 30, 2008 11:15 pm
by honda crazzy
i hooked up the speedohealer just after the speed sensor. all works well. calibrated it and both kpro and speedo are 100% in check!
