jdm itr with euro ctr tranny. my speedo under reads alot!
is there any way to change the pulses from the speed sensor with kpro. the option to use the countershaft speed signal and change values does not work.
someone please advise
jdm dc5 speedo problem with kpro
honda crazzy
speedohealer
if i use the healtech speedohealer(which alters the pulses from the speed sensor), should i fit it between the speed sensor and the dash, or must the ecu also read this calibrated pulse? will the ecu actually make sense of the "altered" signal ?
is it compulsary for the ecu to read this changed signal, cause i don't use gear compensation anyway
honda crazzy
