Limited Edition S300 R136 & R138
Posted: Fri Oct 24, 2008 3:50 pm
by OTT
To accurately feed the 0-5v wideband signal into D10...
can you definitively tell me if I need to cut R138 & R138?
Posted: Tue Oct 28, 2008 4:38 am
by jordancivic
R136 and R138 yes, i had this issue a while ago and Hondata confirmed this.
Posted: Tue Oct 28, 2008 9:49 am
If you are having a problem then try cutting them.
Posted: Tue Oct 28, 2008 8:30 pm
by SPOOLIN
what kind of problem is a problem? Symptoms to determine if there is a problem would be nice.
Posted: Wed Oct 29, 2008 8:45 am
If the datalogged voltage does not match the voltage on the pin (using a multimeter), then remove the resistors.
Posted: Sun Nov 02, 2008 5:24 pm
by Jaker
Is it safe to say that if the resistors are there that they should be removed? Are there any repercussions to removing them for no reason?
