Help with the hondata s200 w/boost on a 95 teg ls
gob_2k
Post by gob_2k »
Ok, so we install the rc brand new injectors for the integra (they are 550) and the hondata s200 w/boost set to stock base map since they didn't have any maps, and it wont start. When we get it to start it runs really rich because we can smell it on the exhaust, but the apexi turbo timer a/f value says 10.0 all the time. Can anyone help? Oh, the afc is still wired in since we have to drive it to the shop to get it dyno. Could this be the problem?. Thanks
Mark216t
Post by Mark216t »
Has the system been programmed for 550's ?
If not remap the base map for the bigger injectors - or use SAFC to lean the 550's right off
If you dont have the means to remap or lean off the 550's - refit the std injectors and run carefully with the lowest boost you can - 1 - 2psi to where you are getting it tuned. you can do this by loosening the wastegate/running a weaker spring etc.
with 550's you are currently injectoing about 2x as much fuel as usual!
Mark
