doug or somebody please look
ASSALBERT
Post by ASSALBERT »
i got 3 dyno pulls done at church automotive a couple weeks ago to get my air fuel ratio checked out. i drive an 06 rsx type-s with cold air intake, jdm spoon header (with stock cat), exhaust and the hondata reflash and the pic below is the reading that i got. i was wondering if it is a safe a/f ratio BECAUSE im going to be racing my car at the track (road racing) and the rpms are going to be in the upper revs for prolong periods of time and i dont want to damage anything. i also posted this specifically in here because i know you guys work with shawn and church auto alot and ive heard that the tail pipe sniffer method they use to determine a/f ratio acutally reads leaner than what it is supposed to be. also, having a cat on the car messes up the a/f ratio as well. i want to know what hondata thinks?
You will need to ask Church Automotive, as the AF readout from each dyno is different.
