K20A2 JRSC KPRO HIGH MAP SENSOR DATALOG
carbonctr
Post by carbonctr »
I have the JRSC with 3.4in 9PSI pulley fitted to my UK Civic Type-R with stock MAP sensor. On my datalogs I get MAP readings up to 156 kPa. Now that equates to 22.6PSI or 1.55 BAR. If I was really getting that kind of boost I think most of my engine and catalyst components would have shattered the windscreens of fellow road users. My car runs fine so can anyone shed any light on this matter?
I have attached a short datalog of one WOT run...
If anyone is interested on AFR values the conversion is:
ELD V AFR
1.333 = 7.350
1.958 = 10.358
2.681 = 13.366
3.413 = 16.374
4.145 = 19.382
4.853 = 22.390
4.994 = 22.991
fonz600
Post by fonz600 »
It's just the way you have kmanager setup.
if you subtract circa 14.7 for atmospheric pressure you get your boost.
Go to options, sensors then MAP and change units to "/PSI and it'll read what boost you are running with atmospheric subtracted automatically.
carbonctr
Post by carbonctr »
Nice one! Cheers! I suppose I could just subtract 100 from the kPa value to get the same result :-)
Go to options, settings and change the units to read correctly.
carbonctr
Post by carbonctr »
Spunkster wrote:Go to options, settings and change the units to read correctly.
Why is there no "/kPa option? I have it currently set at "/psi which will do just now.
