S300 CODE 16 AND 3
Posted: Mon Oct 13, 2008 5:52 am
by turboh22a
JUST INSTALLED PRECISION TURBO 780 CC FUEL INJECTORS NOW IM GETTING A CODE 16 AND CAR IDLES REAR ROUGH, BUT IF I TAKE CAR TO 2000 RPMS IT SEEMS TO RUN FINE. THAN I GET A CODE 3 ALDOR FOR A MAP SENSOR, IM CURRENTLY RUNNING A GM 3 BAR.. ON TOP OF THE PISTONS CYLINDER 1 IS CLEAN, 2 IS DIRTY,3 IS DIRTY, AND 4 IS ALSO DIRTY. ALSO CYLINDER 4 SMOKES WHEN YOU REMOVE THE SPARK PLUG? CAR SEEMS TO HAVE A LOT OF SMOKE AND SMELL RICH BUT PLX WIDE BAND SHOWS 14.5 AT IDLE? SOME ONE PLEASE HELP IM SO CONFUSED ON WHATS GOING ON?
Posted: Mon Oct 13, 2008 11:46 am
Posted: Mon Oct 13, 2008 11:51 am
by turboh22a
sorry for the caps, my computer is on caps lock all day at work.
Posted: Tue Oct 14, 2008 2:14 pm
by turboh22a
ill post my calabrations as soon as i get my internet at home so i can get on my laptop. im running a p72 ecu with a h22a 9.1 compression, darton sleeves stock head arp everything
calabrations
Posted: Thu Oct 16, 2008 9:56 pm
by turboh22a
heres my settings
Posted: Sat Oct 18, 2008 7:52 pm
by turboh22a
car runs..some reason the map sensor isnt functioning? car runs rough and smells really rich but wide band is at 14.5. any ideas. someone
Posted: Sat Oct 18, 2008 10:44 pm
by turboh22a
i jsut installed me original map sensor and the numbers went through the roof to like 56568????my gm 3 bar was stuck at 70.. someone help with this and i keep getting map sensor codes and fuel injection codes
Posted: Mon Oct 20, 2008 9:39 am
It sounds like you have a wiring problem. If a map sensor is wired incorrectly it will be damaged. Test your components on a known good vehicle.
