wideband lambda conversion problem
Posted: Sun Oct 12, 2008 12:32 pm
by Wolli
hi to all!
everytime, when hondata brings a new update, there are more problems than before. maybe i´m the only one, but i do not think so.
the software was working well and almost stable, till i made the update yesterday. now, i cannot change the lambda conversion to match with my lc-1. i know, that hondata will say now " the innovate lc-1 is not good", but this time, it cannot be a problem with it.
the next thing is, that there are new points in the smanager, but not in the manual. so we users must search the new things, and try a lot, till we find out how it works. a lot of people tune the cars by themselve, so hondata should also update the manual!!
maybe one of you can help me with the lambda problem, cause everytime i change the values, they jump back to the same numbers as before.
thx, wolli.
Posted: Sun Oct 12, 2008 12:51 pm
by Wolli
now i tried something different:
i opened an older calibration file, changed nothing(!!), and saved it with a different name. and look at that: the lambda conversion values changes to something that no one can need!
i get silly with this shit! what are you doing at hondata?? i allways tell people, that hondata is great, but sometimes i really wonder!
Posted: Sun Oct 12, 2008 7:19 pm
by Martian
what version were you on prior to the update? You may need to rebuild a new file.
Posted: Sun Oct 12, 2008 9:34 pm
by Wolli
that´s another bad joke. you have to make a new map much to often! but i tried to make one, and nothing changed. i´m not able to set the values in the conversion tables to what i want.
started the car in the morning to drive to work, and it´s running very lean at idle. and when i raise up the fuel tables, nothing changes. the car ran great on friday, with the old smanager. but now, it´s undriveable. i slowly get really angry about hondata.
@hondata: when you bring out a new update, please tell us, when the tuning maps are not compatible with the old calibrations!! and also how to handle the new options would be fine.
Posted: Mon Oct 13, 2008 11:45 am
There should be no difference in the way your car runs when changeing from one version to a new version. The lambda conversion table will have no bearing on how your car runs as that is just a datalogged value. We are currently looking into the lambda part of the conversion tables as the A/F portion works perfectly.
Posted: Mon Oct 13, 2008 1:15 pm
by Wolli
the problem was, that the fuel ect compensation was wrong. the maximum was 65° celsius. so when my car was getting warm, it made a -50% correction. and that was the reason for running lean. and the same problem was with the a/f to lambda. i found an old thread, where another one had exactly the same problem. so i made a new map again today, and then it worked (at the 2nd try!). there is a big problem with different units in the software. i had to program with a/f and ° fahrenheit, then it worked. but when i try to set a/f back to lambda, i have the same problem again :cry:
