Not Reading Boost Correctly?
Posted: Thu Oct 09, 2008 8:38 pm
Setup:
B18C1- 81mm ~9.5:1cr
USDM P72 ECU
Hondata S300
Hondata Boost Control Solenoid
Hondata 4-bar MAP
RC 750cc Saturated
Walbro 255
Inline Pro Mani
T3/60-1 .63a/r
3" Turboback
Tial 38mm WG- 13psi Spring
New Autometer Digital Electronic Boost Gauge
Issue:
Boost gauges read 13psi at full boost
Hondata reads no more than 8psi
Hondata boost cut set at 10.5psi- Never hits boost cut at any point during pulls
Already Tried:
No boost controller- the Hondata controller was disconnected- no effect
Different Hondata 4-bar- Had another one around the shop, put it on- no effect
Different Boost Gauge- plugged in a mechanical Defi gauge- no effect
Thoughts? Car runs mint, seemingly no vacuum leaks, no stutters, car makes 8psi power levels...am I over looking a vacuum leak? Then why isn't the car stuttering?
USDM P72 ECU
Hondata S300
Hondata 4-bar MAP
RC 750cc Saturated
Walbro 255
Inline Pro Mani
T3/60-1 .63a/r
3" Turboback
Issue:
Already Tried:
