Having Trouble Locking Cam Angle
ElecTech
Post by ElecTech »
I'm having trouble getting the ECU to "lock" the cam at the angle put in the tables. For example, if I try to tune the 0 deg. map and put 0's in all cells, then reflash the ECU, the cam angles still change in the scanner. It is as if not all of the changed parameters or tables are getting written during the upload.
I have tried two different computers without success. I had success with older versions of K-Pro a couple of years ago, but recently I can't get it to work. Any suggestions?
Jaime
What version of software are you using? Have you tried going to Online, Tools and clearing security before uploading?
ElecTech
Post by ElecTech »
I'm using 1.3.0. I did try clearing once before and it didn't seem to work. I'll give it another try when I get the car back Friday.
BuiltRSX
Post by BuiltRSX »
I am a newb to this, but I recently had a faulty tensioner that wouldnt allow me to change cam angles, is it possible yours may be bad or faulty, or is this realated to ECU issue? I am just curious.
