Ignition Timing???
Posted: Mon Aug 18, 2003 4:18 pm
by toddjlarson
Hi, I have recently accquired a turbo B18C1 running Hondata Satge 2b.
Should the ignition timing be set to stock, and allow the Hondata to retard per boost.
I was told this in another forum. Sounds reasonable, just wanted to check.
Thanks.
Posted: Tue Aug 19, 2003 8:10 am
by DaX
Correct. Stock timing is 16 degrees BTDC if I'm not mistaken.
Posted: Thu Aug 21, 2003 8:40 pm
by toddjlarson
Ok, thanks, DaX.
Posted: Sat Aug 23, 2003 1:47 pm
by toddjlarson
Also, does it make any difference if I am running a PR3 ECU with an OBD-0 distributor on the B18C1?
The stock timing would still be 16 BTDC?
