Ignition Timing???
toddjlarson
Ignition Timing???
Post by toddjlarson »
Hi, I have recently accquired a turbo B18C1 running Hondata Satge 2b.
Should the ignition timing be set to stock, and allow the Hondata to retard per boost.
I was told this in another forum. Sounds reasonable, just wanted to check.
Thanks.
B18C1
T3/T4
Stage 2b
DaX
Post by DaX »
Correct. Stock timing is 16 degrees BTDC if I'm not mistaken.
toddjlarson
Ok, thanks, DaX.
B18C1
T3/T4
Stage 2b
toddjlarson
Also, does it make any difference if I am running a PR3 ECU with an OBD-0 distributor on the B18C1?
The stock timing would still be 16 BTDC?
B18C1
T3/T4
Stage 2b
