MIL Flash for Shift Light?
Posted: Sat Sep 27, 2008 11:10 am
by BMR
Is there any way to activate the MIL light as a shift light like the S300?
THanks
Posted: Mon Dec 01, 2008 2:21 am
by LK7R
This featrue would be so great! ... Hondata?
Posted: Wed Dec 17, 2008 5:14 am
by LK7R
Bump ... please?
Posted: Wed Dec 17, 2008 9:49 am
Probably not going to happen. The MIL is already used for knock indication, and it would be best to keep the operation simpler. If you want a shift light output you can use a nitrous output to drive a LED.
Posted: Thu Dec 18, 2008 12:20 am
by LK7R
Thank you for the reply.
Or Immobiliser / EPS light :)
OK so with nitrous:
First wire from LED to 12V and second wire to E18/E20/E21/B6 (Ground) ? (not sure about the wiring)
K-Manager settings / Nitrous control:
- Arming input - Always on
- Engine speed set to RPM window where LED should be ON
- Engine load to some low value
- Throttle to some low value
- Vehicle speed to 0
- Knock count to 0
- Fuel and Ign - no corrections
thank you
Dan
Posted: Thu Dec 18, 2008 9:45 am
Sounds ok.
Switch 12V to one side of the LED. Other side of the LED to the ECU (E20/E21) using a resistor to control the current.
Posted: Fri Dec 19, 2008 1:31 am
by LK7R
Good!
Will test it out.
cheers
Dan
