Help! my cams don't follow the cam command properly..
if you look at my attached file you can see that my cam angles vary a lot +/- 1-5 degs.. i have never seen this before on anyone elses kal.. I mean there are some variances on other peoples kals but not above 1 deg.. mine goes crazy.. look at my kals and please if anyone knows whats wrong that would be great because I think im loosing power from this anomoly.. I have a 02 rsx with i/h/e/rbc/kpro..
thanks for replying.. ive already checked the vtc solenoid and vtec oil strainer is the past (the strainer at the back of the engine) but the vtc strainer (the strainer at the front directly behind the P/S pump) is hard to get too.. i dont know how to get too it without removing the P/S pump and im kind of intimidated by doing that.. and I use amsoil full synthetic but right now im trying royal purple.. is there anything I can buy that can flush through the system and clean out the gunk? and the po314 error is unchecked
Garrett_si
