Datalogging Randomly Dies
Posted: Sat Sep 06, 2008 6:38 pm
Hi all! Out of nowhere, my datalogging randomly has been shutting off. It only does it at higher RPM's, though. Almost seems like something is coming loose, or something along those lines. When I pull the USB cable and plug it back in, it's fine again. I haven't had a chance to try using a different laptop just yet, as I've been getting ready for a race tomorrow. I figured I'd just toss this out there and see if anyone's experienced the same? I checked, double checked, then triple checked all my grounds. Everything is nice and snug. The ECU checked out to be working just fine on another car upon loading their map to the ECU. Oh, and when I try to download the map off the ECU, SMan FREAKS out and starts spitting an error, at which point I have to kill the process in task manager. (Bad USB driver? Bad USB cable? Bad Hondata output port?)
A couple of times, the car would just die on me in 4th gear, and come back to life after tapping the throttle a couple of times - CEL would pop on, then when the car comes back to life, it would go away. No datalogs, as it's acting up on me obviously. :(
Also, anti-lag is hit-and-miss. Sometimes it works, sometimes it doesn't. Seems to stop working when the car gets warm, somewhere around 195-200*. My slimfan is kind of gimpy, so I've decided to run pure water + water wetter, hopefully that helps keep the car cooler (runs best around 180*). I heard the Hondata temp. compensation is kind of gimpy - any truth behind this?
- 2000 Civic Si, LS/VTEC, boosted, GM 3bar, RC1000 Inj's, E85, 5,280 ft. elevation, PLX-M300
- P28/Hondata S300/Boomslang harness
This map IS dynotuned, other than part throttle which is gimpingly street tuned for now. Oh, and another thing... how in the world do I get auto-tune to work? I was trying to figure out how to turn it on to have it auto-tune my part-throttle, but I couldn't find any way to turn it on.
Thanks a bunch, all.
