Upgrade duty cycle
burtcrx
Upgrade duty cycle
Post by burtcrx »
Hi, I run a 2.4 turbo(t3/t4)8psi and I tried the k23RDX fuel injectors 410cc... theyre too small but summer ends soon, id like to know in which window can I upgrade the duty cycle of my injectors...or if you have a new pre-made setup thank you...and at what about should I upgrade it( 90%)?
Thank you
dustyboner
Post by dustyboner »
The fuel injector duty cycle is the percentage of time the injector is supplied with power. its calculated by this formula:
injector pulse width (ms)
------------------------------------- = fuel injector duty cycle (%)
time the engine takes to
complete 2 revolutions (ms)
So with the Kmanager, when you increase a value on the fuel tables, it increases the pulse width/duty cycle.
It is recommended not to exceed 80% duty cycle. You need 550cc injectors for your setup.
cranny
Post by cranny »
what car is this in? what fuel pump you running?
