Map sensor issue on k24a2?
davisj3537
Well I installed a k24a2 into a base rsx and we are having problems with the idle. It runs exactly like if you were to tap the wrong map sensor location on a rbc for the 05-06 models. It is running the stock tsx manifold and currently I'm using the map location on the manifold. I tried switching it to the TB to check but it wont even start when plugged in there. Anybody have any ideas? Still using the base engine harness and already modified the tps sensor.
davisj3537
Perhaps if you were to follow the posting guidelines: http://www.hondata.net/forum/viewtopic.php?t=3629
davisj3537
Touche sir. I'll regather my thoughts and include a datalog and cal later this week. Sorry for the waste of bandwidth.Hondata wrote:Perhaps if you were to follow the posting guidelines: http://www.hondata.net/forum/viewtopic.php?t=3629
davisj3537
davisj3537
davisj3537
davisj3537
Well my comment was directed towards the fact that there are a large number of people running short ram intakes. I gathered from your response that the intake temps were exceptionally high(possibly higher than most would see even on a short ram intake). We are in texas and it was 100 degrees that day...he had driven about 45 minutes to get over to me for the datalog. I thought the intake temp was normal all considering.
davisj3537
Here is a new datalog with the changes made you suggested. I also removed the throttle cable adjustment so you can see the poor idle. He held it at around 800rpms for a few seconds but the last 10-15 seconds is primarly what we are looking at.
davisj3537
