KMANAGER COMMAND LINE PARAMETERS?
Posted: Mon Sep 01, 2008 2:51 pm
by carbonctr
Hi Hondata
Are there any command line parameters we can use with KManager yet? Datalog/record on startup would be handy.
Another handy feature would be to autosave a datalog on closing KManager or shutting down pc in case of forgetting to save it. I've datalogged a couple of times and lost it by switching off the car ignition making my carpc shutdown before saving.
Posted: Tue Sep 02, 2008 8:46 am
In the help file see V1.2.4 under "What's New"
Posted: Tue Sep 02, 2008 10:41 am
by carbonctr
Hondata wrote:In the help file see V1.2.4 under "What's New"
"? To automatically start datalogging when KManager is started use a command line parameter of 'datalog' (without the quotes). "
Nice one! I missed that as I went from V1.2.3.5 to V1.2.8. Don't think I used the car when the in betweens were released. I'll change my startup menu command line next time in car :D
Posted: Sun Sep 07, 2008 5:35 am
by carbonctr
Is there a way to start KManager with a calibration open and datalog at the same time?
I like KManager to open the currently loaded calibration each time it starts. I normally do this by putting the calibration in the startup folder so it is opened by KManager. I can't find a way to add the "datalog" parameter when opening KManager this way....
Posted: Mon Sep 08, 2008 6:48 am
Make a shortcut to KManager. Edit the target to include the calibration name and then 'datalog'.
Posted: Mon Sep 08, 2008 8:08 am
by carbonctr
Cool....I have made a shortcut with the following target:
"C:\Program Files\KManager\KManager.exe" C:\"Program Files"\KManager\Calibrations\kal.kal datalog
It loads up okay on my laptop but will try it in the carpc this evening to see if the dataloggin works....
WORKS A TREAT!
Many thanks :D
