Need help with A2 Cam Base Calibration
d4nvu
Post by d4nvu »
Previously I had a set-up with IPS K2 cams and later switched to stock 02-04 type-s cams. currently my car is running like shit and i was wondering if anyone could take a look at it.
This is the current mod list:
02-04 Type-S cams
Type-s rocker assembly
440 cc injectors
type s cai
base header/cat/catback
type-s intake manifold/tb
fonz600
Post by fonz600 »
Your running rich as feck.
You don't need 440 injectors. Put in standard 310's maybe be an idea as you won't be getting the effiency from the 440's.
If you must stick with what you got Pull out 10% fuel everywhere to start with then try it from there but I honestly think switching to 310's would be a better idea.
d4nvu
Post by d4nvu »
can i do that under the fuel trim catageory under the fuel trim parameter? or would i have to change everything under tables? also my friend told me my primary o2 sensor is busted so he wouldnt be able to street tune it. it through a p0134 code, but i disabled it under kpro. thanks!
fonz600
Post by fonz600 »
You got an error code in the datalog you posted stating that the fuel was too rich.
Your primary is possibly knackered giving the such high readings but it is fluctuating a little.
EDIT*
Your log at idle and cruise doesn't auto correct to 14.7. So your primary probably is knackered.
Try a working one from a friends car and see what you get for readings if possible.
d4nvu
Post by d4nvu »
ok so i got a new primary o2 sensor, and my friend helped me street tune my car. we cleaned the a/f up, but did not touch anything else. this was on the base map type-s--440cc map that came with hondata. the tune held a steady idle and everything looked fine. but the code p0172 came up again.
i attached my new calibration and a datalog. if anyone can look at it that would be great!
