GARAGE SERVICE MODE USING REV LIMITS PARAMETERS?
carbonctr
Post by carbonctr »
Hi
I was wondering if anyone could recommend rev limit parameter settings that would be suitable for setting before putting the car into the garage for a service. I would like to limit the power of my car in case one of the mechanics chooses to take the car for a blast. I thought of just setting the rev limit to 3500 so it could not be driven too hard but am not sure if they need to do a VTEC check during the "test drive".
Any ideas?
carbonctr
Post by carbonctr »
I noticed the Scale TPS option on the Knock/TPS Parameter window...could this be used to limit the TPS to 50%?
Conquistadore
Post by Conquistadore »
I don't think you can use the TPS Scaling for that purpose.
It is a great idea anyway!
A Valet Mode activated by a switch or KManager would be very useful.
I know this is a stupid idea but I would like to share it.
Set the over heating temprature something below 90 degrees Celcius and check Go into 4000 RPM limp mode. In this case everything including VTEC will work but for a short time. Driving your car will not be fun anymore.
Regards.
2002 Euro Civic Type R
KPro (SN:05506, HW Ver.:2.16, FW Ver.:2.02)
Hondata Heat Shield Gasket
BDL 66mm Throttle Body
Fujita F5 Cold Air Intake
Toda Headers
Mugen Power Mid Pipe and Twin Loop Rear Silencer
AEM UEGO 30-4100 Wideband Controller
carbonctr
Post by carbonctr »
Conquistadore wrote:I don't think you can use the TPS Scaling for that purpose.
Regards.
That would do it! I think I'll stick to rev limits just now...
kommon_sense
Post by kommon_sense »
Why not just limit revs to 6500 and raise vtec to 5k? That should still allow the mechs to properly test drive the car without issues.
And/Or just lock all cam angles to 0 which should be the safety map.
