wideband parameter option...where is it?
civicboy96
just like the title says.. using s300 and cannot find the wideband/lambda parameter on the list of parameters. i want to find this so i can select what input to use for the wideband guage. its an aem guage if that helps,and i do believe it can be set to 0-5v output. thanks!!
inteGReddy
Re: wideband parameter option...where is it?
yeah... they changed the location of this setting in one of the updates sometime back. had my pulling my hair out too.civicboy96 wrote:just like the title says.. using s300 and cannot find the wideband/lambda parameter on the list of parameters. i want to find this so i can select what input to use for the wideband guage. its an aem guage if that helps,and i do believe it can be set to 0-5v output. thanks!!
